omri617
How To Protect Your Tires And Keep Them Longlife?
omri617
Hi
Tried to search with no results.
I got myself a set of 4 new tires today , and concerned that they will wear out fast , for the car
makes only 1500-2000 K'M a year , and parked outside , exposed to the hot & cold weather.
Are there any tips / tricks / materials / anything I can use and apply to protect them?
24seven
Can't say I've heard of any specific products to prolong the life of tyres myself, but for me personally just making sure the pressures are correct, make sure the toe/tracking at the front is correct and don't drive around doing handbrake turns or burnouts and any tyres should last a good while.
omri617
How about powdering them once a while?
dcc
cover them in lard. it will impact handling though.
alternatively, use the car more and replace them when the rubber perishes
harryskid
Forget the lard unless you like sliding, just cover them in sacking and poly to keep the weather off them!
Slo
Take em off and leave em inside a spare room when not in use for long periods. Its the cold that perishes rubber more than anything.
omri617
Lard ? what is that?
"" sacking and poly" - what is this , too?
harryskid
Lard is fat from cooking horrible grease stuff! :o
Sacking is the material bags are made off and poly is short for plastic.!
I would not think your tyres would suffer from cold where you live, more from the sun and heat, so covering them from contsant sun would help! :)
TooMany2cvs
Rendered pork cooking fat - great for a heart attack - but I suspect it might be just a minor issue given your location...
To be honest, I think your question might be best asked locally - it's not normally a problem here in the UK, but it's not really 205-specific... I know tyres suffer from UV light exposure, so keeping them covered whilst the car's not in use is going to be your main goal - which will be good for the paint and interior, too. Heat not so much of a problem - they'll get hotter in use.
Edited by TooMany2cvs
