laldy875
1989 Phase 1.5 Fuel Pump Grommet/seal
laldy875
I have replaced the fuel pump, with genuine bosch part, and recently did a pressure check to find 1bar of pressure at prime.
I noticed I have a split in the meiller grommet in the fuel pump which I think is causing my issues.
Does anyone know the part number or where I could get this from? It's for an F reg 1989 phase 1.5
This could be the cure to my problems! Many thanks
Tom
farmer
sorry gromet comes with pump ONLY not seperate
Edited by farmer
ALEX
Not sure never thought of that, there should be some glue that would work.
If it's gong in the bin anyway, it might be worth trying to melt it back together with a soldering iron?
laldy875
aye cheers good shout. forgot about that technique. Instead made a nylon bush up, got an old hobby lathe in the garage, fitted an oring and everything. ball ache of a job. Seems to be holding up well now though :)
MrStock
I do need that Seal too, do it sure come with the OEM petrol pump?
farmer
I have the seals separate
If you put a wanted ad up, I will reply with a price posted over the weekend
