john-melbourne
Strange Sparking Sound From Engine Bay
john-melbourne
Hi Guys,
I have recently had a flat battery on the CTI so got the jump leads and got the car running, i was just about to check with a multimeter to see if the alternator was charging and i started to hear a strange sparking type sound from the engine bay. This got louder and more apparent as the car was revved. It was dark and there was no signs of any sparks just what sounded like them, i have heard them before but decided as my head was already in the engine bay to have a quick check. I could not see anything out of place or any signs of sparking just what sounded like it?
Anyone ever had a similar problem or have any ideas?
Suppose it could be described as a clicking noise as well
John
Edited by john-melbourne
mang
It sounds like its jumping out of a lead or around the male pin on the coil (where the leads push on) seen it loads you will see it coming out the pin and the lead just run each one through your hand you will soon feel it :-) lol
john-melbourne
Thanks for the reply, stupid question but do I just locate the coil and try and push the leads back on? Could this also cause a flat battery or stop it from charging?
Thanks Again
John
mang
Try push them back on but I would of thought if its jumping out something is foobard (needs changing) it wouldnt cause it to run flat.
john-melbourne
so you think I might need a new coil? or could it be something else that needs replacing?
Thanks Again
John
farmer
if you do buy a new coil get a motaquip one
mang
Coil or could just be a lead the charging is the alternator or battrey :-)
omega
sounds like a cable is either,loose dirty or breaking down.
as you have had battery problems iwould check all the battery leads by removing them and cleaning them[not just looking at them] also check the engine earths.
john-melbourne
Oh my word i am such a plebe! Just remembered when i removed the jump leads last night the negative lead more or less came off with the jump lead! I will tighten this when i get home this evening! Would this be causing my sparking sound and dead battery issue?
John
