jamie_1992
Gti6 Cam Cover Gasket
jamie_1992
do you need a gasket to go between the head and the cam covers
i called peugeot to get a gasket and they told me it dose not have one its a flush fit
upon doing this then relized something is a miss
as the cam covers can not sit flush as as there is lugs where the bolt come through that sit higher than the edge of the cover
i asume the must be some sort of gasket that sits in here or im missing something i cant remember
Your bonded seal is missing, those covers are now useless, there is no separate gasket.
You would have to replace with a new cover, but one is NFP already.
jamie_1992
dam it needs both covers aswell doing
is the no way of bonding a new seal on there
ORB
I would bin that anyway. The paint will come off and clog up the oil ways and pump.
jamie_1992
wanted .... pair of cam covers :)
allye
When I had mine powder coated they removed the seals, its not a massive problem you can use a sealant, not as tidy but does the job. If you go down this route spend a very, very, very long time cleaning both mating faces with some wet and dry ensuring they are spotless! - Bit is a bitch to get it to re-seal.
I tried getting new gaskets but they don't make them, Peugeot told me to use the gasket sealant.
ORB
Surely is would not be hard to get some made up? How thick are they?
CosKev
Quite thick,I would guess circa 3mm.
You can use sealer,but its not ideal,way to thick a bead needed and you risk any excess dropping into engine.
ORB
Could one not be cut from cork like Oldschool gaskets?
jord294
I have a pair of cam covers with excellent seals if that helps?
Looking for £30 inc postage
