PhilNW 43 Posted December 27, 2012 Where's the best place to get bilstein dust covers other than bilstein for a Grp A/N strut Had the blue plastic ones from Bilstein but one has cracked and do not fit under 70 mm id spring properly Share this post Link to post Share on other sites
welshpug 1,646 Posted December 27, 2012 (edited) The inverted damper with small i.d spring doesn’t use them, as you noted they don’t fit. Edited December 27, 2012 by welshpug Share this post Link to post Share on other sites
PhilNW 43 Posted December 27, 2012 its a road rally 205 wanted something to keep the crud off are the strut seals sufficient? Share this post Link to post Share on other sites
PhilNW 43 Posted December 27, 2012 anyone tried a steering rack boot? Share this post Link to post Share on other sites
Toddy 7 Posted December 27, 2012 anyone tried a steering rack boot? That's what Skip Brown Cars use Share this post Link to post Share on other sites
PhilNW 43 Posted December 27, 2012 any particular make and model? Share this post Link to post Share on other sites
Dizzee stuff 33 1 Cars Posted December 27, 2012 You could try motorcycle fork gaiters Share this post Link to post Share on other sites
matt.f 16 Posted December 27, 2012 I know that the proper blue ones are £20 from bilstein,mine had to be ordered in from germany Share this post Link to post Share on other sites
EdCherry 34 1 Cars Posted December 28, 2012 The strut wiper seal should be sufficient, and if it isn't there could be a couple of reason's why: 1) Your not cleaning it often enough 2) You haven't replaced it often enough 3) The design is crap As is mostly the case, all 3 apply. Share this post Link to post Share on other sites
PhilNW 43 Posted December 28, 2012 always had covers on them which is why i want to replace them good enough for skip brown etc etc Share this post Link to post Share on other sites
EdCherry 34 1 Cars Posted December 28, 2012 If we all lived by the motto 'good enough' then we would never progress. Eibach sell some dust covers which encapsulate the spring as well, made from a neoprene fabric I believe. Share this post Link to post Share on other sites
