jamie_1992
205/306 Gti Rack
jamie_1992
Will a 306 gti steering rack fit on my 205 xs
Fitting is the same as a Xsara VTS rack in terms of adaptation needed, but the GTi-6 rack is lock-limited due to the 6 speed (and slower than the VTS).
There's certainly no advantage in fitting it, if that's what you're thinking.
jamie_1992
I need a new rack and have a gti6 rack spare and just wonderd
What is a good rack to fit if I want quicker steering
johnnyboy666
xsara vts will be least turns lock to lock or a 205 PAS one will be less than a non PAS 205 one
EDIT: before I accidentally give you the wrong information, the xsara VTS rack will not fit on the xs subframe, but will fit straight onto the GTi subframe, due to the different gearpost positions.
I assume there may be a similar issue with PAS 205 rack but I havent tried
Both of them would either need the PAS bit blocking off or a PAS pump etc retro fitting
Edited by johnnyboy666
The other thing is that if you're using the MA gear posts then I don't think you can use a PAS rack, or certainly not the PAS part anyway.
Not done it myself, but I remember pictures from someone that tried on here and it fouls on the gear post.
Edit: here's the picture of a PAS rack fitted to a MA subframe:
Seems that a small part of the rack needs to be cut away to gain sufficient clearance to fit, and no chance of PAS pipes fitting.
Edited by Anthony
jamie_1992
I have a gti subframe I am going to be putting on plan was to do rack at the same time as I'm having to move the gear linkage any way I could always try fitting something in or would it be much work to remove the pas part of the rack as I'm not having pas
Doesn't matter whether it's a base model or GTi subframe - it's that you're using the MA gear post rather than the BE one (which is in a different position and clears the rack fine, hence PAS being available on XU and XUD models of 205)
jamie_1992
Could i not use a BE gear post?
