allye
Compomotive Th Supplier 16X7
http://www.willtheyfit.com
if you go 8" you'll need a fairly low offset.
Going by the fact that a 6.5" ET29 Ouragan/nimrod will JUST ABOUT fit on a 309 without any spacing, I would imagine you'll need an offset lower than 9mm, illustrated below at the same inset.
you're looking at a minimum of 35mm more poke than a standard wheel.
http://www.willtheyfit.com/index.php?width=185&aspect=55&diameter=15&wheelwidth=6&offset=19&width2=205&aspect2=50&diameter2=15&wheelwidth2=8&offset2=9&Submit=Submit
probably safer at a 0 offset.
Edited by welshpug
