Keljon
Rear Seats Wet
Keljon
have done a bit of reading and seems the rear lights, boot lock and spoiler are common areas for leaking, what do people use to seal these areas properly?
matt.f
Could also be rear quarter glass
Keljon
i have seen it coming in the boot area when i washed it so fairly sure its the spoiler or boot lock, just interested to know what people use to seal it?
johnnyboy666
tigerseal would probably do it, but depends on whether you want the bit you are sealing to be removable in the future!
dcc
I have always used RTV if Ive had a leak. If its window seals then a bit of grease or engine oil will do the trick!
flipperthebushkangaroo
Also worth a look at the washer jet, they come loose and let water in.
PeterGriffin
Did you manage to find the solution buddy? Struggling with a puddle in the back also... Thanks!
Keljon
It's not my daily driver so have garaged it for the moment to let it dry out, will seal the spoiler, wash jet and lock and see how it goes
PeterGriffin
Yeah, I'm thinking the same, bought some black silicon sealant from B&screw but don't have a dry environment to apply the stuff...! :(
farmer
be rear quarter window seals they shrink something terrable get them in hot water and stretch them as getting new ones is a no go
Keljon
Top tip, thanks
farmer
carefull not to get to over zealous as you will split them gradual pressure
dave richards
also look at the gaiters near the body at the top of the boot lid my car has an issue with one of them popping out and allowing rainwater in
TaffyTim
anyone know a better place to get the rear washer jets from, mines buggered and lets water into the boot, when i lift the tailgate it finds its way out of a drain hole but its like ive turned a tap on.
there are some on ebay but 7 quidish
farmer
Peugeot !!
