vtifan
Hub Offsets
vtifan
what are the offsets, track width on these parts compared to 1.9 gti parts
1 base model xs front hubs,does the wheel mounting face sit closer or further away from the shocky
2 rear beam skinny drum brake type,how much narrower is this compared with the 1.9 disc rear and the 309 disc rear beam
trying to figure out if i am going to need spacers on my wheels,with wheels fitted on base hubs i have about 4 mm gap between inner rim and shocky,the wheel looks spot on with the outer arch though so dont want to have to spacer it if possible
on rear they are rubbing on inner wheel house but only the tyre rim protector ,but looks like i have a bit of room to play with so the wheels can be spaced out a bit with no outer arch issues
wheels are 7.5x16 et20 front and rear
