Carbs4me
Gutman Wheels, 309 Running Gear?
Carbs4me
Just a quick one!
Will my 205 which already has a 309 rear axel fitted, will the gutman wheels fit or will it cause massive problems sure my axel is lowered by 30mm too!
Depends on the wheel width and offset basically, but if they're 7" with an offset bigger than about 10 or so, yes you'll have issues on the rear.
Carbs4me
he sent me this it makes no sense to me - 7jx15H2 ET18
Makes perfect sense, they're 7x15" with an offset of 18!
If they're the ones i think they are, he wants far too much money for them.
Carbs4me
Are these them?
Is the verdic they wont fit within my arches?
Look like the same ones yes! They'll fit but i think even if you ran skinny/low profile tyres they'd eat the arch trim!
Are yours actually the same rims though Josh? i might be wrong but i though they were Exip's and had a ford offset etc?
lemmingzappa
The rims are identical but just the wrong offset, as i'm using the adaptors they should be balancing out from ET38 down to ET18.
Ahh i see, that confirms my thoughts about the EXIP's being identical but the Guttman ones just being 'rare' for the namesake then?!
lemmingzappa
Pretty much, it's just the centre caps which are different. I have heard about an 8J version in the correct fitment but never seen them anywhere.
iirc you can't fit big brakes under these wheels either but I don't have any experience with that.
Tesstuff
Were Gutmann the same to Peugeot as AMG is to Mercedes, Alpina is to BMW?
Sort of yes!
You spelt it correctly too, unsurprisingly! :P I always mix it up!
These exips look like they have tons of caliper space, far more than a rwd ford fit TH :/
dcc
I told him earlier they were far too overpriced.
I wouldnt give more than £150 for them ... with tyres :|
By the looks of it the guy is a moron.
Tesstuff
I have read his posts on Facebook. He is a grade A moron indeed.
He also needs a triple slap combination for his grasp of the English language.
Henry Yorke
Proper 205 Gutmann Exip wheels should be 7 x 15 ET 13, though they sold a huge range in all different sizes. Those pictured above look like the later dished type and these seemed to be more ET18 than ET13
They are ET18. And yes I have to agree with above, but of a pleb.
calvinhorse
but of a pleb.
Tesstuff!!! Quick tell him!!! He wrote but instead of bit!!!
Baz you mong!!!
:lol: Silly phone auto-correctings!
calvinhorse
Yeah whatever thicko! :D
Carbs4me
I was looking at these today!
Clicky
Been a 16" tho which i can only presume they would case even more havoc!
marksorrento205
I am with Baz on this one. I look after a car that has Gutmann wheels and a 205 beam. I would not fit a 309 beam on that car.
vtifan
Clicky
i think they would fit pretty well,good offset
