Rob Thomson
Decent 1.6 Gti Driveshafts?
Rob Thomson
Hello chaps,
Any recommendations for a supplier/manufacturer of decent recon driveshafts for a 1.6 GTi?
Mine are crap, both from local factors but couldn't tell you the manufacturer. Neither seals properly (never had that problem before in years of Pug ownership) and I've never been happy they're the right length or fit into the hub properly.
Are there any out there which are guaranteed to fit properly?
Cheers, Rob.
sensualt101
speno has some for sale in a thread on here right now if its any help :)
OE / GKN's!
Rob Thomson
Thanks.
I thought GKN probably best bet, will try to find some.
John_B
Yeah good luck with that Rob. I recently tried to find a GKN 1600 shaft, ended up ringing GKN and they transferred me around in circles for bloody ages. Ended up chancing a random one from GSF in the end which seems to be OK.
It finally cured the steering wheel wobble I've had for years which turned out to be a dodgy recon shaft.
Motaquip used to link to / supply AMK driveshafts when they stocked 205 parts so they could be worth a try, either that or for some good quality ones if you can't find GKN or oe ones, Shaftec or Dave Mac could be worth contacting but their prices will reflect I expect.
g
If it helps, i have a source for some new old stock GKN shafts, has sorted me out a treat! :D
