dave205
Solid Front Sunframe Mounts
dave205
I saw a thread a few weeks ago that i think paul13 started but not sure. Wondered if anyone knew where i could purchase some?
pugpete1108
Aren't they solid anyway? Subframe to body you talking about?
Non-GTi models use a mount between the body and front subframe. GTi's mount the subframe direct to the chassis leg.
205's use a mount with a rubber bush, whereas 309 GTi (and some other XU models) use a solid one.
The solid ones are marked NFP so it'll be a case of finding some second hand.
allanallen
Some base models have rubber mounts on the front mounts, I'd imagine Peugeot to be the only place to get them new.
I'd put a wanted add up on here or look for someone scrapping a shell.
Al
dave205
Ive got the rubber mounts that bolt the front part of the subframe to the chassis leg. Im after some solid ones, like you say that are fitted to 309 gti-s anthony.
Will they firm the front end up? Or is it not worth borthering and chuck some decent rubber ones one's on?
dave205
After re-reading this today i have a question! Gti subframe on to a base model shell, i am right in thinking i can fit it direct to the body?
rallyeash
No. From memory when I went xu running gear on my Rallye I had to refit these mounts.
Would also be interested in solids
as above you do need them, I can only think the chassis leg's are different for some bizarre reason
dave205
Right i'll have to find some solid ones then
