Carbs4me
Which Clutch?
Carbs4me
What clutch can i use for my Mi16 with a S16 gearbox?
Will the Mi16 one fit?
Thanks,
Paul_13
Go back a step and read 4 posts down
1.9 Mi16 will fit
You can use a 1.9 Mi16 clutch, but you'll need to change the clutch arm/fork on the S16 gearbox for a push style one as they're pull style as standard (assuming that hasn't been done already).
Otherwise, you can use a 2.0 Mi16/S16/GTi-6 clutch to retain the pull style arm/fork on the gearbox, but the cable will need modification/adjustment with to make the whole lot work on a 205.
Carbs4me
Is this correct? 215mm Luk clutch
Clicky
Yes that looks about right for a 1.9 Mi16 clutch.
I'm not sure if the offer is still on, but CP4L were doing a 10% discount code on clutches a while back - CLUTCH10 I believe was the code.
Carbs4me
Cheers i will look at that on my dinner!
For a couple of quid more you can have a OE Valeo one from Motaquip, I'd know which one I would use
