Matt205
Brake Lights Staying On
Matt205
Car has failed it's MOT due to the brake lights staying on. Pretty sure I checked all the lights a few days before. I assume the most likely candidate for the cause is the switch on the pedal. Is there are easy way to test the switch? Anything else to consider?
marksorrento205
The switch may just need adjusting?
sensualt101
i think it definitely points to the switch.
as above it may need adjustment and may not have failed.
its a fairly cheap component to replace if neccessary though.
good luck with the next mot
Matt205
Ah! That could be a possibility as I've re-bled the brakes since I checked the lights over.
