omri617
How Should The Boot Brake Light Be Wired?
omri617
Hello guys
The boot brake light is working ok, but i don't fancy the way it's wired. it goes all the way from
it's connectors with White+Blue wires , inside the boot seal up all the way to the brake light .
It causes sometimes water getting inside the boot.
How should i place it?
omri617
Should the wire be passing through the boot? Or where? The way is fitted now seems wrong to me..
omri617
up
Its not original Peugeot fit, and the tailgate doesn't look to have the correct holes for it, but yes the wiring should be routed following the other wiring then across to the middle where the light is.
if it seems wrong, change it :P
omri617
I seems wrong yeah and it lets some water in
on the left of the photo there is a black wire , is it for the glass heating?
yes :)
omri617
where does it lead in the fusebox? :) for some reason it doesn't work in my car.
