Anton green
Dastek Unichip. Ever Used One? Any Comments To Offer On Them Or Their
Anton green
Dastek unichip. Have you ever used one? Do you have any comments to offer about them, their use, or Dastek?
Cheers, Anton
♥Mods.. Please move to engine management section. :)
Edited by Anton green
stef205
Had one on my saxo vts, as far as I can remember it aloud you to map the engine with the standard ecu. A piggy back ecu
(null)
hcmini1989
Sounds good ,Whats involved with fitting these?.Is it a 16 pin socket in place of the normal Chip wich the piggy back then plugs into?.
Anton green
I'm not certain what is involved in fitting them and the dastek site was only half working when I recently took a look at it. As said above it is a piggyback ECU.. but so far I don't have a mass of knowledge on them, I know they used to be reasonably popular but then they either disappeared out of the limelight or I became out of touch with them...
Anton green
(null)
Stef, did you have any mapping done -was it any more involved and did you have to see a 'designated' tuner only? Good results with it, or was it simply installed when you bought it?
stef205
It was on the car when I bought it but had it mapped. My tuner said there wasn't a lot of movement. Was a good 5-6 years ago mind. But since buying a omex for the 205 it well worth the money.
(null)
How much are they these days? But your limited by people that can map them, Installation is normally splicing into the ECU loom from the few I have seen installed,
I think now the time you factor in these reasons a complete aftermarket ECU works out cheaper
Keljon
bit old skool now, there are better solutions even if you just want to still go piggy back
Anton green
The price seems to vary wildly on the second hand market. I believe the product has its uses and I have heard no bad reports so far apart from a lack of flexibility, regarding installers and the alterations achievable. I'm going to keep my ear to the ground and see what I can learn about the different products Dastek do. I'm in no rush.
