Iain-gti
Wheel Stud Conversion
Iain-gti
Hi,
I'm looking at getting wheel stud conversion but there's two lengths 60mm & 80mm which one? I'm running team dynamic pro wheels with no spacers. Pretty sure from memory they should be tapered nuts.
Regards
Iain
AlexRS2782
From memory the TD Pro Race wheels require a 60degree tapered setup. That's the taper used on the 1.2's on my Saxo VTS and also the same taper used wth the wheels on a Ford with the same bolt pattern.
Without spacers a 60mm stud is long enough to use the flat face open nuts on standard wheels or any in a suitable offset, 80mm studs are only needed if you are running wheels with spacers.
If you are only using wheels that take a taper seat nut, a 60mm stud will be plenty long enough.
g
Iain-gti
Thanks for the reply I have ordered 60mm
