GWtaylor
1.9 Axle To 1.6?
GWtaylor
In a previous thread i asked about a pug i was hoing to view and its a 1.9 with a 1.6 rear axle on is this a pipular conversion?
speno
One of my 1.9's has drums on the back , i cant be arsed to change it back even tho i have the axel sitting in my garage
someone might correct me but 1.6 drums good for handbrakes and 1.9 better stopping power
stef205
It's more likely to be a 1.6 shell with a 1.9 engine hense your 1.6 beam. I've not seen a true 1.9 with a 1.6 axle I don't see why they'd do it.
(null)
The only real difference between them is that 1.9 is disk brake and 1.6 drum brake, and it's open to debate which is "better" - disks are easy in terms of maintenance and work well, whereas drums have a far better handbrake
Rare for a 1.9 to have a 1.6 beam retrofitted, but could have been done because the original failed (common) and they could only find a 1.6 replacement, or perhaps they were using it for something like rallying or autosolos where an effective handbrake is important.
As said, it's more likely to be a 1.6 car that's had a 1.9 engine fitted - this is quite common
make sure it actually is a 1.6 beam, Goliath had a 205 GTi with a base model beam on it!
speno
Mine was done by the previous owner he was going to do autograss or something in it , so he wanted to do better handbrake turns ^^
Edited by speno
GWtaylor
Thanks for that
I think i'll just walk away as o want an original 1.9
GWtaylor
Is there anyway of finding out if it an original 1.6 or 1.9
Have chassie number
GWtaylor
Anyone
Would chassie number tell if its a 1.9 or 1.9 shell?
Yes.
dcc
I will add to this thread by saying that my 205, 1.9 gti shell, is fitted with a 1.6 rear axle. I dont care about the Extra braking power of the 1.9 axle (if any). The right beam came up at the right price at the right time for me.
GWtaylor
What should the engine code be to state 1.9?
D6B, DKZ, and a few others.
