ben205turbo
Electric Windows To Windy Windows
ben205turbo
hi does anyone know if its possible to change from electric windows to windy windows? thanks
Dizzee stuff
Just change the window regulater to a manual one.
ben205turbo
are they simple to swap over? and thanks
farmer
very easy took me 15 mins do drivers side take door card off and pocket then its just a few nuts easy peasy
ben205turbo
ok will look for 2nd hand regulator though as £160 to downgrade how my windows go up and down is a bit much.
farmer
thats just for drivers side the passangers a diff part number they do retail new from pug at around 90 i believe
ben205turbo
does it have to be from a gti?
farmer
as far as am aware 3 and 5 door regs are diff so need be a 3 door reg if you have 3 door i strongly advise getting a new reg where you can as other regs are at that age now so could be a case of buy cheap buy twice
Slo
2 door gti, 2 door cti and 4 door models have different regulators which model have you got? youll also need window winder handles as well obviously
Edited by Slo
farmer
Edited by farmer
ben205turbo
I've got a 1987 1.9 gti and i can source a cheap 1.6 auto for bits
farmer
if the auto is 3 door and manual be good to go
farmer
made mistake on service box before CTI is diff part number so apoligies SLO
ben205turbo
cool thank for your help
jamie_1992
why would you want to down grade i hate having manual windows wish i had electric
as above! why?
farmer
personally i prefer manual and have had both now
ben205turbo
because i have carbon fibre door cards to go on and the holes are all there for windy windows and don't want to chop them up for pockets and switches
Got a cage?
ben205turbo
yeah got a sparco 6 point bolt in to go in but getting paint work done first
I think the point Welshy was making was that depending where the door bars are, you might not be able to use the winder handles - not such an issue if it's a new cage as you can position the door bar appropriately usually, but if it's a used one you're refitting you might have a problem.
Another option (that I would personally do) is to just relocate the electric window switches to the center console somewhere - easy enough to do, particularly on the pre-Phase 2 cars. Just extend the wires as required.
ben205turbo
oh didn't think about that good point yeah its 2nd hand off a friend. i may relocate the wires would only have to do drivers side too. thanks
Yes, Anthony hit the nail on the head, a few cars I service for still have their leccy windows as it would be impossible to wind them due to the door bars, I don't know if this would be the case with the OMP, certainly seems to be with most SD and CC items.
ben205turbo
cheers glad i asked here first otherwise would of been rather stroppy lol thanks again
