dartman
Front Brake Conversion Base Model Hubs.
dartman
hi all
just purchased a set of 1.9 gti front brakes discs and pads, was wondering what is needed if anything to fit them on my base model 205 xl, im running gti 15' wheels so calipers should fit behind them whats the best way to deal with the brake lines? cheers, dartman.
Direct fit - just need some 1.9 caliper bolts.
dartman
can you use the same lines and connecters?
stef205
id say while the front lines are off it would be wise to change to 1.9 hoses
allanallen
1.9 hoses aren't a direct fit as the solid lines on base models are routed differently
