johnnyboy666
Dummy Shock Settings For Thicker Torsion Bars?
johnnyboy666
I have just got my hands on some 23mm torsion bars, and am wondering what dummy shock length I should use as a starting point to get approx 25mm lower than standard gti height?
is there a general rule of thumb to work it out for different thicknesses?
or has this already been covered?
There are some guidelines for dummy shock settings for thicker torsion bars on here somewhere.
They are only suggestions though as it depends on the ride height when sat on the car but they will give a decent starting point.
With 21mm tb's
For 23mm tb's I think I'd look at a starting point of about 302mm.
g
You'll want lower than that for 23's - I'd say around 292mm, give or take a couple of mm.
Depends on who made the bars, aftermarket ones do vary in my experience. Certainly for my 23mm bars in 309 width your dummy damper length needs to start with 28 to get a decent ride height.
pugpete1108
sorry to butt in but im going to be changing my trailing arms soon (ish) and cant remember the length for a 30mm drop on std bars etc. 310/330mm rings a bell?
I usually use somewhere between 312-314mm depending on the front springs to match 30mm lowering.
pugpete1108
Cheers Tom, may have been 313 I set it to last time then.
Unknown brand springs but I'm sure they were 30mm
johnnyboy666
just to update this; I've just popped the new bars in (23mm from the recent group buy) and used 280mm for the dummy shocks, which worked out perfect and almost exactly the same as it was with the standard bars which was 312mm I beleive
hopefully this will serve as a guideline for anybody else doing the same swap :)
