NFS
Difference In Cti An Gti Carpets
NFS
Question above. What's the difference?
dcc
the rear section where it goes up to the rear seats. iirc its quite a bit different and the moulding is different too!
NFS
Oh okay thanks
Slo
floor pans are deeper inner sills are wider i think
All of it basically, Front footwell's are narrower due to the kick panels, Behind the front seats where a large cross member fits to name a few, I have seen GTi carpets fitted but it looks nasty
Mark.Azzop.205
The front foot-well of the carpet for the CTI goes up higher than for a GTI. In a CTI there is no side kick panels. The sills are wider in a CTI so the bulge is longer and so a narrower footwell. The one below is from a GTI :
Now this is from a CTI :
Also notice the CTI has an additional patch in the driver footwell to protect against wear from feet rubbing due to lack of kick panels
Hope this helps
NFS
Yes thanks, there was a job lot of parts going for sale which inculded a cti carpet. i was just wondering if it could fit the gti and i couldnt find the answer buy searching on here and google. but thanks great help
omri617
What is a good way to renew the color of the carpet , after washing properly?
Mark.Azzop.205
Good question, it's been talked on here before, IIRC someone said that carpet dye will not work because the material of the shag pile of the carpet is nylon and the dye doesn't stick to it or dye it! I cleaned mine with Ariel Actilift liquid soap and it came up mice, but I guess a faded red carpet from the sun is irreparable or I don't know how to do so
Slo
I spray painted mine after i jetwashed it in true wheeler dealer style, its worn off a lot now as you can imagine but it looked a million dollars when i did it lol
Weser
I gave mine a good wash and scrub with washing powder and it came up a treat even though it looked a bit faded.
