starky5
Be3 Gearbox On Mi16
starky5
I'm half way through my mi16 conversion and I'm having issues. I went to fit my clutch and gearbox yesterday to realise the clutch didn't fit so I've just picked up an mi16 clutch to suit the flywheel. It's appears to be a pull not push compared to my old clutch, will the work with my gear box?
Any help will be amazing I'm getting the to stage of pulling my hair out now haha
take it back and ask for a BX16v clutch :)
starky5
I was worried someone might say that! The petrol might be coming out soon!!
As Mei says, you've been given the wrong clutch - you need a 1.9 Mi16 clutch, but sounds like you've been given a 2.0 Mi16 clutch which is pull rather than push. It's a common mistake motorfactors make when ordering 405 Mi16 parts.
BX 16v's only ever came as a 1.9 Mi16 and hence it's generally a safer bet ordering parts for that rather than a 405 - just be sure that it's BX 16v and not BX GTi (which was a 1.9 8v)!
starky5
Do you know if the required clutches cover diameter is 200mm or 215mm? Trying to work out if ive ordered the wrong clutch again or not!!
1.9 Mi16 clutch is 215mm
Your original 8v clutch would have been 200mm.
starky5
I really should stop rushing when things go wrong! Ive ordered the wrong bloody clutch again!!
