pugpete1108
Best Way To Clean Carbon Off The Tops Of Pistons
pugpete1108
I need to give the xu7 block a good clean up and I need to remove a fair chunk of deposits from the tops of the pistons.
Was just going to use a wire brush on the drill ? Is it safe enough to do do without damaging anything?
Obviously will do it with the piston at tdc
calvinhorse
I mite get a telling off for saying this..
IMO the cheapest and best engine cleaner is petrol. Stiff brush to scrub the block and a firm scouring pad for piston tops, nothing to abrasive on pistons.
You could then give the Block a polish with a fitting on the drill if you feel the need.
Use goggles and gloves if you use petrol it's nasty stuff but works a treat
High alkaline degreaser is a lot safer.
pugpete1108
Ok cool, what about the crap that falls down the oil/water ways?
Can it be flushed through with a solvent ?
You didn't mention it was insitu.
there's only one "waterway" :lol: and that would be easy enough to flush the bits out of, and you can tape over the oil feed and both returns.
you do have the liners clamped down nicely don't you?
calvinhorse
Britain wasn't built on safety you Australians are all soft :P
pugpete1108
Liners clamped down yes, engine removed yes :)
What us the area around the liners called then? What snout getting crap in there
laldy875
I used a paraffin bath for my pistons and with a bit of work with a scourer pad, and fine wire brush came up really good. Or you could use petrol as mentioned above. Blow all the FOD away with an air compressor.
How bad is it? H/g? I've been told it's better to leave things untouched if your not going to dismantle everything properly, i.e. the bottom end, if you are getting good oil pressure. You will probably get more compression with the carbon deposits on the top of the pistons.
Edited by laldy875
pugpete1108
Only planned on changing the head and doing crank seals sump etc.
nixonmi16
I always use oven cleaner have been for all my engine rebuilds . oven pride from asda 3.99 melts all carbon clean off or soak the pistons in redex also works just takes a lot longer
