johniban
[Car_Upgrade] 1.9 Gti Rust Repairs And Bodywork
johniban
more parts through the post,
got the fuel lines tidied up
46FF2284-BFC1-48A8-BB7F-D94A31B83094_zps
465FC001-7B8F-4BE6-8CE8-091D6F9EB96E_zps
374D26AC-2FBE-4B95-8F89-F46547334ECD_zps
will no doubt be changing the fuel line set up soon as want to buy one of miles inlet manifolds when funds allow and run 8 injectors
johniban
Little update, decided to sell the 205 rallye as it was just sitting at the back of the lock up gathering dust and i cant even get this project finished let alone that one, so sadly that went, but has given me a bit of money to buy some decent parts for this.
So thanks to Miles i have a satchel engineering inlet mani, i was never too happy with the previous mani, it never fitted well and the trumpets wouldn't clear the bonnet.
This one sits perfect, im over the moon with the quality, now i can run 8 injectors too,
9219844F-40EB-4CC6-8927-380B99585239_zps
CF63ABEC-BAEF-4591-85DA-8AF22F6217CF_zps
850ADED0-E5DC-47B6-8946-947C7B01CFA9_zps
Not too happy with where the fuel reg is sitting, its ok but doesn't look too neat
if you plan to run 8 injectors you can do away with that aftermarket regulator totally and use the standard gti6 one.
johniban
i really don't like the look of the standard fuel rail, looks really nasty in place ontop of the inlet mani, im trying to find an alternative, i have tried the jenvey rail in place but obviously the mounting holes don't line up. must be a way around it
Lol, works well enough for however many thousands of xu 16v engines psa have made.
wont look any different to anything else that fits and does the job as well.
johniban
yes it may do, but im already running four injectors in the bodies with AN fittings, i cant see that the standard fuel rail will really work i need one with fittings on either end
johniban
Thanks to Colin at pug performance i now have a sexy looking exhaust manifold that fits perfectly, saves me alot of hassling about with the reangled manifold and making up a down pipe
3C0D9207-5A96-49B4-8E3C-2BE56CA091A5_zps
916E84F8-019B-4A50-A71F-3B7632CB7151_zps
18B110EC-106F-477C-BE50-E5C04DA9688B_zps
johniban
exits out a 2.25 inch so not too big of a bore,
pain in the arse trying to remove the old one
034EC65B-4FE3-4925-ACF6-F870E18FD51D_zps
new manifold fitted
659B460E-87FB-49A8-AF87-9DF44D011F87_zps
6654AED5-D8BB-452D-8F35-8EAC44C4D70B_zps
clears everything nicely
johniban
New radiator purchased, some reason its came through gold! doesn't look too bad, added two 12 inch slim line fans to it, probably a bit over kill
20DE440F-1C90-4528-A3FE-735330A1CA6D_zps
Interesting to see your manifold fitted OK, joys of 205 build, the 1 I fitted was right up against the seem on the exhaust tunnel and a mates one hung down too low so he had to shorten it, One reason why I doing my own later in the month.
Rad wise I'd send it back if you can, that type of rad is pretty poor, the Nissens types are by far the best for cooling, I;ve always known quite a few issues with the fine fin ones
2052NV
its probably the body on your 205, i know with mi16 conversions some bodys you dont even need to reangle the manifold at all..... i believe in the 80's/90's french body manufactoring tollerances were very loose :P
johniban
Yeah seems ok so far, currently awaiting exhaust tube and welding gas to make up the rest of it.
As for the rad it was only £30 so will do for now for mocking up
johniban
started on my wiring loom, stripped down and took off what i dont need as will be using omex,
F278826D-67A0-419D-8047-4994AE80F8B6_zps
johniban
ran the loom back into the car to work out the lengths between sensors so i dont have a load of spare wire all over the place, all mocked up and nearly ready to be soldered and heatshrinked
F1A08096-9B3A-41AB-8BAA-FAE8DACE6FEF_zps
the wiring will be attached to the bulkhead where its near the exhaust mani and relevant heat shielding will be added
2F12748B-3EB7-4FE8-ACDB-F6278FBF951E_zps
johniban
Now on to the front end, radiator needs to be lower so made up a new lower cross member,
E7573021-0972-47FD-9552-BD8CF2987912_zps
BC67F6C1-FDDD-4BA9-9EB5-AE23A0C22858_zps
876DCBB6-2288-43A4-A039-BA5BED8DB203_zps
johniban
mocked up a new slam panel
C13F8B90-60BF-45E6-B595-09AECAA7DE76_zps
21B925E9-A107-4785-8C1C-C8DF9F1D5265_zps
D01FB413-BD2C-4D5F-AAED-E32A57A7174F_zps
2389DD82-EDA1-4A88-927D-2731E61ED739_zps
83088044-8D40-438A-B4B2-FE2E97DBCAAE_zps
8B4764DF-B194-4371-B122-0C73ED460F06_zps
johniban
obviously needs welding fully, cleaning up and painting, ideally i would like to be able to find someone to copy it into ally but im not to bothered
I personally would not run the wiring there, given I have seen the standard grommet get melted by a gti6 manifold...
johniban
I had thought about moving it to the nearside but the new manifold is miles away from the grommet compared to the original mani and I'm going to be using a heat shield
jamie_1992
will an air filter still fit in there looks quite tight
johniban
if i use smaller trumpets it will but the car wont be an everyday car and alot of people dont run a filter so i dout i will
johniban
Slowly doing bits to this as and when i can witch at the moment ive not been able to touch it due to other commitments,
Have been trying to collect parts to get the brakes plumbed in, and first on the cards i needed a pair of rear calipers, after searching most places, calipers were either in worse condition that mine of they want a ridiculous amount of money for them so i have decided to just pull my finger out and refurbish mind,
Started with the strip down on one caliper
055B6910-E42F-4502-83BB-DC63BA2F1086_zps
All came apart ok, nothing seized and nipple came out fine,
Pistons and sliders will be going in the bin and replaced with fresh new ones
50114B8E-C965-4FC9-8A31-1CB978A99DFE_zps
EB6DEF71-26C1-4C1D-B4D9-EB2573760900_zps
CBE9E221-2C65-445C-B498-32E0FC388D5A_zps
johniban
Quick coat of mercedes silver
D7CAEBB5-D5F5-489A-AA7F-0294B1EB8EEF_zps
johniban
Well no pics of the calipers built up, but they are on and bled,
Been busy trying to get it run this weekend,
made up a coil pack mount, maybe not the prettiest of things but it does the job well, bolted to the head with some hardish rubber washers to try take out some vibration,
DA88E5EE-FEAF-4DA1-953C-3618FF0F66D2_zps
Bought some vauxhall cavalier HT leads that fit perfectly,
22050F87-CE11-4E74-A116-4062E5F6288A_zps
Then after damaging one of the o rings on the fuel rail i decided to get it welded so i wont have any future problems with leaks
C4FD445B-D6C0-4ED2-81A2-B8F8FFFD1856_zps
johniban
Time to do a job i was dreading as im pretty useless at measuring and cutting steel..
31031D92-592D-4ABC-B085-9EB17086A017_zps
Used a hole cutter and then a die grinder to get the holes perfect
B4BB80C1-D12F-4C2F-8515-59B794A9A480_zps
