ORB
Speed Sensor
ORB
Can someone confirm something for me please?
I am about to put a XU10J4RS into my 205 using the 1.9 but with an MI16 clutch.
I am aware I need a Speedo Sensor for the ECU, but not too sure exactly what one I need? I am guessing its 6160 24 but not 100%
Will this fit my 1.9 box? (are the gears the same?)
I am aware I will need to trim the box a bit near the mounting point for the sensor.
Anything else I need to know, fundamentally, is this the correct unit?
Ta
ORB
That's the one Mr Welshpug!
When you say change gears, I assume you mean pull the gear off the bottom of the 205 speed sensor and put it on the new one?
Yes - it just pulls out of one and pushes into the other, thus keeping the speedo accurate.
Thanks for this topic, I dropped chriswb's turbo loom back to him a week or two since & we needed to find a suitable three pin vss with speedo cable drive to get things working properly.
Sweet. :)
g
ORB
I'm waiting mine from EBay as we speak. I did pay by cheque though as I WONT use paybumyougoodandhardpal
Now we know what we need, chris will probably get his through work but ebay is a lot cheaper than dealers for the same part!!
g
ORB
I work at a main dealer, even at cost it was about 50 quid
That makes the ebay one an absolute bargain then!!
Service box price was almost £100. :o
g
