stuart1298
Mocal Sandwhich Plate Question
stuart1298
Right, I have limited space on my engine bay, I'm looking at one if These mocal sandwhich plates, and do they work in the way as the normal plates just thinner?
I'm not sure that they're much thinner than a standard 1.9 oil-air cooler sandwich plate, although much thinner than the heat exchanger setup used on most XU10 engines.
I've got a couple of spare Mocal sandwich plates in the garage if you're needing one?
stuart1298
Well I'm using a Renault oil filter as there only an inch or so deep, but I haven't got the old oil cooler or bolt, so thinking that might be an easier idea, took the old bits out now I've lost em :(
mang
Yeah they fit with a normal filter on just plus they normaly come with a temp valve in them to let the oil heat up ;-)
Alan_M
You can get them with or without the thermostat.
If the OP wants measurements, I have a Mocal thermostatic take-off plate in the garage.
mang
I know you can get them without just dont see the point my aswell get one with car will get to running temp qwicker
stuart1298
I was bein an idiot. The mocal oil cooler allows the oil to flow trough it's own rad, rather then water to cool it. Just bought a full setup up, cheers people
Josh_Quant
What Renault oil filter you using mate?
been trying to find out what smaller oil filters can be used for a while!
They're used on loads of the older ones, R5, 11, 19 etc, much the same dimensions as a pug filter but half the height.
Just pop to a motorfactor and they'll have them on the shelf most likely, just explain what you're after, have a look at the filter catalogue, make sure the threads match (M20)
Clio 16v/172/182 etc too.
Josh_Quant
Cheers Welshpug and Baz!
stuart1298
Do you want a part number?
Josh_Quant
Yeah make things even easier lol
stuart1298
No probs, I'll grab one of the shelf and give you the GSF number and manufacture number
