ginge191
3 Door Carpets Into 5 Door?
ginge191
Amateur question perhaps; but never touched a 205 before, and unfamiliar with the in's and out's
As titled; are they the same? will door carpets fit a 5 door?
Cheers.
Servicebox makes no distinction between 3 and 5 door, only for Saloon and Convertible and left/right hand drive.
ginge191
Thanks pal; ill give it a go and see what comes of it :)
BERTMAN
You'll find the 3 door carpet's have small slits that have not been fully cut around the B pillar area. If you slice these with a stanley knife the 3 door carpets will fit perfectly into your 5 door. The slits help the carpet fold around the B pillar.
Edited by BERTMAN
ginge191
Ah ok, i understand - easy job!
Thanks for the info :)
