Dariooo
How To Tight A Nut On Gaz Coilovers?
Dariooo
Helo
I had buy a gaz coilovers on Group Buy. I had assemble it and I don't know how to tight a nut on the top on rod. The problem it's because I can't fix a rod and when I would tight a nut, they rotate toghether. How had you resolve this problem?
Thank you
Dario
max0
Is this the top nut? where on the standard strut you can use an Allan key to hold it as you tighten it? I had to borrow a cheap battery powered impact wrench
Liquid_106
Picture speaks a thousand words:
Might need a 'swan-neck' spanner to fit in the top mount?
Dariooo
yes, the top nut which fix the bearing and the top mount. On gaz I can't use a Allan key because it's some nut to adjust the hardnes.
max0
Yeah you need an impact wrench which does the nut up really quickly, it caught me out as well :(
Dariooo
Oke...I will try with pneumatic Impact wrench.
Thank you
PS:
I have like this:
max0
Yeah that brings back memories lol. What lb springs are you using?
Liquid_106
Sorry, didn't realise :blush:
Install guide says to use a windy gun, so guess that is the only option!
There's small spanner flats on there if they are as per your picture, use those.
Dariooo
I can't use spanner flats because I must tight before a nut for 10 screws or more.....
blandy
Ive just fitted my gaz gha's and the adjuster in the center seems to sit pretty high and the bonnet nearly fouls on it, is this normal
42500ED7-4616-4BA3-95B8-499B3B03B1E4_zps
