kyepan
Why Does A Coolant System Pressurising Stop It Overheating?
kyepan
Simple question.. or silly question..
or is it just that the system can run at over 100 deg and pressurise.. instead of getting to 100 and boiling.
cheers
J
Increase working pressure and you increase the boiling point, run a cooling system with no pressure cap and it will boil sooner, that then causes it to spew water out, which reduces coolant capacity, then you have a vicious circle.
Charles's Law.
Slo
With a 205 its sods law and usually when your skint
http://www.engineeri...ater-d_926.html
look at the second graph, 1 bar is normal air pressure, so the usual 100 degrees C, next line across is 2 bar, which is the usual expansion tank cap release pressure inclusive of normal atmosphere pressure, so 1 bar system pressure, the temperature is circa 120c, the TD and most later pugs run at 1.4 bar which would be around 130 c.
bit more on Wiki
https://en.wikipedia...i/Boiling_point
Edited by welshpug
dcc
Take note that water in an engine is also NOT pure H2O.
or rather, SHOULD NOT be pure H2O ;)
grandos
Being pedantic it should also say 'overheating' in the title and not 'overhearting' like some love sick puppy!
cheesegrater
Same reason as why water boils at a lower temp at altitude!
