eastlondonpug
No Reverse Gear Lock On Be1 - No First Gear
eastlondonpug
Hi,
Car - 1988
Gearbox - BE1 lift up reverse
I have replaced my clutch cable today. It was a 3 hour job and a good experience. I have now adjusted the cable properly too.
However, I got a new problem now.
Every time I try and select first, it goes into reverse. What seems to have happened is that the reverse lock is not working.
I have done a search on the forums and according to one of the old posts it seems to be a reverse cable issue (that may have been stuck open)
I dont really know what to do next, or how to locate this cable to look at further. What do I do next?
Can somebody please help.
Cable screws into the top of the box, Should spring out when you remove it
eastlondonpug
Thanks a lot, I fiddled with it and is working properly now.
Pete C
Mine got too close to the exhaust manifold and seized inside the casing - shouldn't be so much of a problem on a car with a standard engine but might be worth checking that it's well behind the heatshield etc.
Edited by Pete C
