cybernck
Cable Operated Conversion For Be3 Gearbox
cybernck
I've never looked into it as I've only had bad experience with cable shifter on my old 405 T16,
but now I'm thinking of using it on 205 Mi32 - IF it allows for precise and tight shift to begin with...?
I've done a search but haven't found any conclusive info on what parts to use for the conversion,
but apparently 806 gearbox mechanism and any floor mounted gearstick mechanism should work
when coupled with cables of the right length?
And finally, does anyone have any pics of the gearstick mechanism from below? I need to see it
to be able to work out how to fit another pair of cables going to the rear gearbox :).
Henry Yorke
Didn't Hilgie use a C5 cable shift for his V6 conversion?
that's not a BE gearbox, but in essence yes Nik get the matching cables and bracketry from a BE equipped vehicle.
cybernck
Which vehicles would that be? 406 and 806 all 2.0 models?
How do they feel / perform?
And most importantly, I really need to see a photo of the gearstick mechanism from below,
to figure out if it will be possible to attach another set of cables for the rear engine :).
cybernck
Thanks, but I need a photo of one with the bottom cover removed :lol:.
Hilgie
I have used both. I had a cable operated 806 system on my old trackday car.
Anyway...got pics from both if you like. It shouldn't be any problem driving both gearboxes from 1 stick.
Tesstuff
Edited by Tesstuff
interesting, the ones I have used were metal boxes.
cybernck
Photos paint a thousand words - that's brilliant, thanks Daz!
What car are they off exactly?
Tesstuff
Peugeot 406 Coupe. :)
rallysteve
^ Specifically the V6 with reverse below 5th gear ^ :)
Hilgie
405 T16 has a metal one.
cybernck
Is the Coupe V6 gearshift system the same as on a 2.0 Coupe/Sedan?
Goliath
The cables are different lengths but otherwise the same yes.
Only the later D9 generation though isn't it that use cable setup on lower spec models?
Earlier D8 models with BE gearboxes use a conventional gear rod setup as far as I know.
Correct Ant, every D8 I've done a clutch on has been a 1.9 DT with a BE3/4 box and gear rods.
The 2.1 TD and the 2.0 Turbo used ML boxes and cables in a D8, all the same cables as the V6, other than the rare D8 DW10.
looks like the D9 also uses rods on the BE3/4 box other than on the EW engines (which would be XU5/7 and 10), DW's use ML which are all cable.
Edited by welshpug
Goliath
Sorry I should have said I was meaning specifically the D8 2.0T which I believe used an ML box and had cable shift :) (at least when I was doing my V6 conversion and bought a cable linkage I was sent one from a 2.0T coupe and it had different length cables but was otherwise the same).
there are differences depending on age.
cybernck
:blink: Sooo... What car / engine / year am I after again, for a BE3-compatible system?
not a 406 :lol:
Ballyafb
Any luck figuring this out. I would like to do this for a BE1. People say the 406 coupe (apprantly before 1998) or a C5. But looking at some systems, the parts needed would surely be the gearbox bracket, a gear stick and could the cables be made custom?
Otherwise it does not look too bad. I have a friend who used the stuff from a Megane I think, but BE4.
Ballyafb
Done a bit of research, and come up with some info....
A BE4 cable set should fit, as the bracket on the gearbox looks like it will fit any BE gearbox.
This means that a 206 180 should work, or a xzara / 306
http://www.shop.cae-racing.de/index.php?a=46&lang=eng
