dandanger
Speed Sensor Gti6/be3
dandanger
does anyone know where i can find a speed sensor thats mechanical for my speedo yet electric for my ecu hoping it will sort out low end jerkiness ... any links would kindly appreciated.... i think i have an be3 box but is there any tell tail signs so i can be 100% or do sensors fit in all boxes equally
S@m
Best get down the scrappy - The sensor is easy to spot because it has both an electrical plug and a hole for the speedo cable. Most likely found on phase 1 306's and citroen ZX's in my experience.
Sam
EDIT - i see what you mean now, the way to tell if its a BE3 is that it will have reverse below fifth/next to fourth - unless its a 6speed box, in which case its definetly a BE3 anyway.
Edited by Sam306
EZ Tutty
Have a search on ebay for 616024
Should be able to get a new one for £15 or so
Fairly sure they fit BE1 and BE3 boxes.
Edited by EZ Tutty
dandanger
thanks guys item now bought hope it will sort out my low speed jerkyness
Doubtful I'm afraid as it's more to let the ECU the car is moving or it sort of comes on Cam so to speak, without them they do run fine
dandanger
dammit i was hoping this would sort it out.... think a clean of the throttle body may help... then clean up connections... grr i want a garage its getting cold out!
dandanger
Thats just what i needed! thanks
