Karl
Changing From 1.6 Be1 To Vts Box
Karl
no miles!! i have a pedal sourced from anthony for £10 i looked on ebay before but couldnt find the arm beacause i only searched for "be3 clutch arm" not clutch fork kit or whater it was welshpug has posted for me i think i will be getting this so thanks mei the price is not to much of a problem i wanted to buy a box from yourslef miles but i have just been laid off from work as im a plasterer and where i am the building trade has disolved so i only have a maximum of £200 to spend on getting my gearbox and i would prefer not to bodge the existing cable and just do it properly but thanks for all your help
Karl
If its just the pedal you need, i may have one.
i have already agreed a price for one with anthony thanks but if that falls through for whatever reason i will bear you in mind thanks
Karl
right i have finnally got m money for my gearbox change and im going for the vts conversion but im going to fit a 205 diff instead of 'bodging' the inner drive shaft just wondering if i still need a dual vss
yes you do still need the dual VSS if you are using the gti6/vts engine management.
cheesegrater
You dont need a be3 clutch arm just the fork. I'm using the VTS arm and its fine.
you do need the arm IMO, it places the cable end fitting at the wrong angle and it hits the casing before reaching full travel.
cheesegrater
Hasn't given me any grief but not saying youre wrong!
The later type arm can be modified with careful (or otherwise) use of a grinder to stop it fouling the casing - here's one I prepared earlier...
Works nicely after that and gives good clutch feel/action, although clearly in preference I'd rather have used the correct arm.
Karl
ok guys thanks i have ordered the full kit off ebay as welshpug posted for me so thanks for that :)
