vtifan
Jacking Car
vtifan
is there anywhere safe to take the weight of my 205 at the rear except the rear beam or jacking points ? i am needing to do the sills so cant use the jacking points,car isnt too heavy at the moment theres no interior etc just the weight of the beam until i can drop it onto floor,cheers guys
S@m
Why can you not just use the beam as you have suggested?
Sam
brian j
Under the front subframe?
Obey_R
Sam
It sounds like me like he wants to drop the beam once its up then replace the sills
It says rear lol
vtifan
Sam
i have a lot of work to do under rear of car and beam getting in the way,i could always just drop the tank and do the sills then put it on jacking points and drop the beam but i was hoping to get it up high and get it all done in a oner
speno
cut some 4 by 2 wood and drop it onto that ( on ramps or stands ), infront of the tank , i did this with mine but it was a bare shell , so might not work with components on
Edited by speno
