omri617
Fusebox Clips Broken-How To Lift It Up Again?
omri617
Hi
I always see that the fusebox is always dropped down and it's clips are always broken.
I don't like the way it looks! and always wanted to fix this and take it up all the away again.
How can I?
chipstick
Do you mean the front sliding clip which holds the board up is broken? If so, source a replacement.
mhyphenl
  On 8/28/2012 at 8:24 PM, omri617 said:
Hi
How can I?
They always break because people don't put the cables back neatly when they've had it all out! There shouldn't be much resistance when you push the fuse board up and pull out the catch. If its being pushed back down by the wiring above they break quite quickly.
omri617
yeah , that's the case
are there any replacements?
i searched ebay . nothing.
mastakilla
On mine I used a piece of elastic rope that keeps it in place...any 205 I've seen has the original clip broken = faulty design
Mine is fine :)
Put a wanted up.
S@m
Someone has bodged a strange metal clip on mine so if suddenly hundreds are availbale, i'll be interested!
Sam
tartanbloke
I still have the original clip on mine, as well as the coin tray cover still springing into action.
omri617
found it. thanks
