Davro
Brake Bleeding Issues
Davro
Hi everyone,
I'm just tidying up my phase 2 1.9 GTi and am having a few issues bleeding the #@*king thing!!
I've fitted the following parts;
New standard master cylinder
New copper pipes front and rear
braded hoses to front
new discs all round
news pads all round
I've just started to try and bleed it all but for some reason I can't get any fluid through the drivers side front caliper and the passenger side rear caliper!! What am i missing??
Also when fitting my drivers side rear disc I can't seem to get the disc level with the pads in. It just wants to sit pissed. I've tried winding the piston back in whilst forcing the caliper out (see Haynes manual) but that doesn't seem to be doing much......
Any advice or a point in the right direction would be much appreciated....
Dave
Try using a pressure bleeder. New MC's can be a pig to initially get fluid through sometimes using the conventional "pump the pedal" method, and sounds like you're only getting fluid through one half of the MC at the moment (assuming that it is plumbed in as per a standard 1.9 with diagonal split)
Old callipers? the nipples can block up
Davro
I thought of the old calipers issue but then took the nipple out completely and still no fluid.......
I'll grab hold of a mate that is a mechanic and see if he has a pressure bleeding system and give that a go......other than that I am stumped......might have to look at buying new calipers but don't really want to do that.
Cheers lads
Dave
Top the master cyl reservoir right to the top, then leave the front caliper bleed nipple on the troublesome circuit totally removed. Sometimes doing this will allow the fluid to gravity bleed through and displace the trapped air. Once you have got the fluid through it will bleed as normal by pumping the pedal.
HERMAN
I used a syringe and sucked it through from the caliper end to get it started.
If thats any help
Davro
I cracked the front drivers side pipe at the master cylinder and pumped the pedal and all I got was a bit of bubbling, but no flow of liquid. So I tried the rear passenger side pipe and got the same. I then tried the front passenger side pipe and got a nice flow of liquid.
As it is a brand new master cylinder I don't think that is at fault.
I thought of the compensator but would that affect the front brake as well as the rear??
One thing that crossed my mind was a dodgey servo but wasn't 100% as I can get the front passenger side and rear drivers side brakes to bleed perfectly......??
Is it a pattern one or OE master cylinder?
Davro
It's a patent part. I'll get the manufacturer when I get home.
Could it be the servo being knackered?
servo wont affect this at all, it merely assists you in pushing the pedal down.
de Noir
cheers lads
some interesting thoughts here, I'll try asap as I can not get rid of spongy brake pedal
got new everything, except the calipers F+R
bled the system
still spongy :-(
eh? are you in Cambridgeshire?
