BenV
Brake Fluid Level Warning Light
BenV
The light under the battery warning light (Which i think is the brake fluid warning) comes on when going uphill or around a right hand bend yet i have checked the level both with the car hot and cold and the level is fine, any ideas?
BlueBolt
The brake fluid level light is the hand break light. I know this from experience lol
Can't help with the one that is lighting up tho sorry
It's not a coolant level light is it??
Edited by BlueBolt
Goliath
Which warning light is coming on? If it is number 6 then that is coolant level warning light so you should check to see if your coolant is low, if it's not low then it could be a dodgy sensor in the expansion tank.
BenV
yeah its number 6 but in the 205 manual it calls it a "Low brake fluid and handbrake warning lamp"
BlueBolt
Definitely the coolant... Had that one too on the last 205.
BenV
okay cheers ill take a look
