vtifan 26 Posted August 26, 2012 what is the best offset for a 205 for 16 inch wheels,the wheels i want come in +30 +40 or +42 will any of these even be close to fitting ? i want them to fill the arches,am using 1.9 205 running gear,cheers pete Share this post Link to post Share on other sites
welshpug 1,646 Posted August 26, 2012 none of the figures will be anywhere near, for a 6" wide wheel Peugeot used ET19 wheels, the 6" 3/4 SL434 IIRC are ET15. depends on the width. Share this post Link to post Share on other sites
vtifan 26 Posted August 26, 2012 none of the figures will be anywhere near, for a 6" wide wheel Peugeot used ET19 wheels, the 6" 3/4 SL434 IIRC are ET15. depends on the width. the wheels are 7x16 et 30,so i would have to use spacers then as wheel will be well inset,are hubcentric spacers any good as had a bad experience with crap spacers on my s16,how much leeway do i have for inset on the 205 before a start having clearance issues with the inner wheelhouse/strut dont look like much lol, Share this post Link to post Share on other sites
vtifan 26 Posted August 26, 2012 so et30 with a 15-20mm spacer will be pretty close to ideal i think Share this post Link to post Share on other sites
Cameron 16 Posted August 26, 2012 I wouldn't call it ideal, but it would work. Why 16" wheels? 15" are plenty big enough for a 205.. they look silly on anything bigger. Share this post Link to post Share on other sites
BlueBolt 156 Posted August 26, 2012 They look silly on anything bigger. Quite agree!! Don't know the wheel size but you get the hint:: Share this post Link to post Share on other sites
welshpug 1,646 Posted August 26, 2012 they're only 16" Share this post Link to post Share on other sites
Baz 421 Posted August 27, 2012 6.75" SL434's are actually ET8, but you can get away with more. I have some ET20 7"s that fit fine. Share this post Link to post Share on other sites
johnnyboy666 195 1 Cars Posted August 27, 2012 (edited) youd be suprised what will fit! be very careful with spacers, that would be my advice, you need to check the wheel bolts for tightness more often and carefully inspect the spacers for mis-shaping or ovaling. if the wheel is likely to be inset more then be careful with suspension clearance (less of a problem if you use coilovers) Edited August 27, 2012 by johnnyboy666 Share this post Link to post Share on other sites
johnnyboy666 195 1 Cars Posted August 27, 2012 a handy tool - http://www.1010tires.com/WheelOffsetCalculator.asp will give you a pretty close estimate, but in practice might need a little fine tuning Share this post Link to post Share on other sites
Baz 421 Posted August 27, 2012 be careful with suspension clearance (less of a problem if you use coilovers) Not always the case, longer springs can give tyre clearance issues. 1 Share this post Link to post Share on other sites
calvinhorse 870 Posted August 28, 2012 (edited) I have et15 17x7 (205/45/17) wheels on my 309gti they have 7mm of clearance to the 2 1/4" coilovers with 7" springs Same set up with compomotive ths (15x7 195/50/15) et 16 is even closer to the coilover Edited August 28, 2012 by calvinhorse Share this post Link to post Share on other sites
welshpug 1,646 Posted August 28, 2012 Ive had an et28 16x6.5 oursgan/nimrod wheel on the front with no spacers! Share this post Link to post Share on other sites
vtifan 26 Posted August 28, 2012 Ive had an et28 16x6.5 oursgan/nimrod wheel on the front with no spacers! they need spaced though cos they look crap on that offset swit in too far especially on the rear Share this post Link to post Share on other sites
welshpug 1,646 Posted August 28, 2012 not really, as they're 6.5" wide they fill the arch just fine, needed a very thin spacer on the back to clear the trailing arm. Share this post Link to post Share on other sites
johnnyboy666 195 1 Cars Posted August 30, 2012 not really, as they're 6.5" wide they fill the arch just fine, needed a very thin spacer on the back to clear the trailing arm. you can't really get thin hubcentric spacers less than 10mm very easily as far as I've noticed, and you dont want to use those multi purpose spacers, they're horrible things! Share this post Link to post Share on other sites
Henry Yorke 269 3 Cars Posted August 30, 2012 I have run a 10mm non hubcentric spacer in the past on the front and rear and it has been fine with no wobble etc. Things are a lot easier if you use non Peugeot wheels as they have a 60 degree taper which helps pull the wheel central. I also ran it on a stud conversion. The downside is that the load is primarily taken on the wheel studs. Share this post Link to post Share on other sites
