B1ack_Mi16
[car_restoration] 405 T16 Restoration
B1ack_Mi16
Have also managed to paint the boot and front wings, in addition to some other small stuff, door handles and fuel cap etc.
And now started sanding the last parts, side skirts, bumpers and rear spoiler.
Had to make a new mounting bracket on the rear bumper, rusted to pieces.
Front wings and boot is fitted. Front wings just testfitted though :) Seem to fit well.
B1ack_Mi16
Now I've painted the bumpers in white, just to better see any flaws and as a kind of sanding filler.
I also welded up a pipe from the thermostat housing to the heater matrix.
And I have started sanding the TSW EvoR rims that I had on my old 405 Mi16. Gonna give them a refurb.
At least I will use these for MOT as I can run the brembo calipers without using any spacer etc. with them.
B1ack_Mi16
Have painted bumpers and side skirts since last update now.
Now I've started prepping the bonnet. Sandblasted quite a bit on the underside of the bonnet, as it had slight beginning rust development on a lot of the sharp edges.
Sprayed the inside white today, hopefully the rust will be kept under control. Painting it red is the next step.
tomcolinjones
what a fantastic project!
B1ack_Mi16
Thanks. It's been quite some more work than first thought. A 405 4x4 certainly is more work than a 205 gti restoration. Lesson learned :)
Have spent more time on it now since last update.
First round of primer/filler on the outside of bonnet.
Fabricated waterpipe from matrix to pump inlet
Engine out again to gain access for some last work needed to be done
Overview of exhaust
Finished the last piece of the matrix return water pipe
B1ack_Mi16
Boring sanding of bonnet
Made a support bracket for the downpipe to avoid bending it on the turbo outlet.
Color shot inside bonnet and on grille
And clear
Also trying to get the garage at my house ready for the T16 to arrive. Plating the inside roof after adding insulation to keep the heat in there. Planning to install a air/air heat exhanger. Track 205 in the background :)
B1ack_Mi16
Bonnet got color on the outside, last color painting on this car for now!
Fitted the first side skirt
And mounted the litium ion battery at the front, decided to move the fuel surge tank to the back, feels safer also, and more easy to have the battery at standard location regarding wiring looms etc
Last painting done! Bonnet turned out 97%, at distance about 1-2m more or less 100% :)
And started on mounting the surge tank at the back
Jme
Just read from start to finish at work.... incredible project keep the updates regular.... gives me something to do at work ????
B1ack_Mi16
Good to hear it's not just me that have lazy days at work these days :)
Just connected up the fuel hoses this evening, so one more thing to check of the list.
X-mo
Love your build <3
Keep going and make some Vid while running that monster ;)
B1ack_Mi16
Things have moved forward a bit since last update.
Bought a MS3 Pro ECU card to be mounted into standard ECU box, using a 2.0 Mi16 loom as base for the engine management, and adding some extra wires where needed.
Painted more wheels, T16 wheels would be ideally on the car, but for MOT etc. I need to use the good old TSW EvoR's from my first car (red Mi16), as these clears the brembos without spacers etc.
Sprayed acid etch primer
Had a baby girl
And Finished the rims
Edited by B1ack_Mi16
B1ack_Mi16
Prepped and painted propshaft
Cleaned roof lining
Mounted ARB to subframe
Engine in again etc.
B1ack_Mi16
Had to buy a spares car to be able to get interior clips that were NFP.
Clips could not be taken out without breaking them, so had to chop them out with the angle grinder.
Carpet and main dash installed
Wings and front plate on
Bonnet on
IC mounted
B1ack_Mi16
Front on, and ready to move it to my garage at home. Easier to get things done then now when I'm a dad and can't drive to the remote garage so often.
At home finally
S@m
Love this project and your 205 one, keep up the awesome work, have been following for years!
Edited by S@m
calvinhorse
Looks so damn good in red, I like the ecu idea.
At home finally
And what a beautiful pair they make!
I like the Mercedes :lol:
Gay.
B1ack_Mi16
Indeed they do :)
Hopefully I can get to use them more in time coming...
Btw. The Merc has 500bhp and accelerated quite nice even with 2 tons attached to the rear :P
allye
Wow! Any more info on the merc, build thread?
tell me its diesel ? :D
B1ack_Mi16
It's a 2.2 petrol. A friends. :) Sleeper with steel wheels...
B1ack_Mi16
Not very much visible progress lately.
I've mounted the 1000cc injectors in the manifold, and got the new 3bar MAP sensor mounted too..
Mainly working on the engine management loom now. Used a 405 2.0 Mi16 loom as base and have added some pins to the ECU plug.
I'm mounting the MS3 Pro Module inside a standard BOSCH ECU box, to make it look as factory as possible.
ECU to be mounted inside Bosch box.
DBG
Love the paintwork. Looks great. Looking forward to seeing it back on the road.
Love the 405 T16. As far as I'm aware, they never made it over here.
