calvinhorse
[engine_work] Supercharged Xu10j4 Project
chris adams
yes your theory is right thats why i said use the turbo to blow through the supercharger. so in theory as the supercharger is direct and spins instantly it will pull the turbo on in to boost and then the turbo will compress the air into the supercharger and the supercharger gives it another compression. so generally your force feeding the supercharger .?
sorri for the thread hijack pony !
Edited by mi8 turbo
chris adams
dp engineering uses the compound setup as i describe on their triple charged 1.4 pug 206
calvinhorse
find your own topic! :P
the dp engineering car only makes 175bhp which can be achived from a na tu engine so in my own opinion isn't a great result..
im not doubting the level of work dp can do, just weather its worth it!
chris adams
have you seen the dyno graph it makes its standard max torque at the start of the graph and yes its still on standard internals so going beyond 175 mark would be askin for it but with forged jobbies the potential of the engine is massive, it was built as engine eye candy not for bhp figure. but well leave it at that. has your brother not got any pics of his build you could post for us to admire?
calvinhorse
Thats a fair point i take it back! yes i posted a link up a while back in general forum!
richieb
glad the block came of use to you bud !!!! i will check on this project time to time see how your getting on !! :) all the best
Guest
