Erlend405Mi16x4
Need Some Help With The Rear Suspension On The X4
Erlend405Mi16x4
Today i decided to finnaly fix my rear suspension and i saw that the return pipe from one of my suspension cylinders had been destroyed by wear, does anybody know where to get a new pipe for cheap? (citroen maybe?) and partnumber, or if its possible to cut away the bad part of the pipe and the use a joint? (any part nr on the joint?)
cammmy
That stuff is all based on a BX. Have a look at some scrappers to see if they have the same bit.
