scoop 0 Posted May 24, 2010 will i notice a difference in acceleration?? Share this post Link to post Share on other sites
cammmy 1 Posted May 25, 2010 (edited) Most likely but how much depends on the condition it is in. The worse the condition, the bigger the difference. Also, is it legal to de-cat where you are? Edited May 25, 2010 by cammmy Share this post Link to post Share on other sites
scoop 0 Posted May 28, 2010 (edited) Most likely but how much depends on the condition it is in. The worse the condition, the bigger the difference. Also, is it legal to de-cat where you are? [/quot they dont give a daam but my engines condition is it drinks alot of oil without any smoke or any leaking Edited May 28, 2010 by scoop Share this post Link to post Share on other sites
MiCRO 0 Posted May 28, 2010 they dont give a daam but my engines condition is it drinks alot of oil without any smoke or any leaking I think cammy ment on condition of catalysator. How much oil does it "drink"? Mine drinks 1l/1000km Does smoke come out when you open the oil cap on the engine while it's running? Share this post Link to post Share on other sites
scoop 0 Posted May 28, 2010 they dont give a daam but my engines condition is it drinks alot of oil without any smoke or any leaking I think cammy ment on condition of catalysator. How much oil does it "drink"? Mine drinks 1l/1000km Does smoke come out when you open the oil cap on the engine while it's running? well i can't figure how to know the condition of the catalyzor but the the catalyzor light does not light, but my engine consumes 3.5 liters every 1000 km maybe less than 1000 km depending on how i run, the more i press harder the faster the oil disappears Share this post Link to post Share on other sites
MiCRO 0 Posted May 29, 2010 they dont give a daam but my engines condition is it drinks alot of oil without any smoke or any leaking I think cammy ment on condition of catalysator. How much oil does it "drink"? Mine drinks 1l/1000km Does smoke come out when you open the oil cap on the engine while it's running? well i can't figure how to know the condition of the catalyzor but the the catalyzor light does not light, but my engine consumes 3.5 liters every 1000 km maybe less than 1000 km depending on how i run, the more i press harder the faster the oil disappears OMG thats waaay too much! If it doesn't smoke when you open the oil cap, the piston rings should be ok. It's probably the valve oil seals then, I don't know if I sad it right, but I ment these roundy things above the head gasket: Share this post Link to post Share on other sites
scoop 0 Posted May 29, 2010 they dont give a daam but my engines condition is it drinks alot of oil without any smoke or any leaking I think cammy ment on condition of catalysator. How much oil does it "drink"? Mine drinks 1l/1000km Does smoke come out when you open the oil cap on the engine while it's running? well i can't figure how to know the condition of the catalyzor but the the catalyzor light does not light, but my engine consumes 3.5 liters every 1000 km maybe less than 1000 km depending on how i run, the more i press harder the faster the oil disappears OMG thats waaay too much! If it doesn't smoke when you open the oil cap, the piston rings should be ok. It's probably the valve oil seals then, I don't know if I sad it right, but I ment these roundy things above the head gasket: i just found out there is some smoke but it comes with high revs but few white smokes, but the head gasket seems to be fine because there is no water leakage Share this post Link to post Share on other sites
cammmy 1 Posted May 30, 2010 Removing it should make the car faster. If your govt doesn't mind you getting rid of it, it just comes down to whether you are okay with the increased emissions or not. Share this post Link to post Share on other sites
scoop 0 Posted May 31, 2010 Removing it should make the car faster. If your govt doesn't mind you getting rid of it, it just comes down to whether you are okay with the increased emissions or not. i just found out that the car doesn't have any catalyzer :D Share this post Link to post Share on other sites
MiCRO 0 Posted May 31, 2010 Removing it should make the car faster. If your govt doesn't mind you getting rid of it, it just comes down to whether you are okay with the increased emissions or not. i just found out that the car doesn't have any catalyzer :D LOL that's actually bady news, now you can't get few more bhp-s for a little money But good news is you allready had that extra bhp-s Share this post Link to post Share on other sites
cammmy 1 Posted June 1, 2010 Also dont have to bother with having pipe welded into place instead of the cat too. Share this post Link to post Share on other sites
