estland1345402287
High Idling
estland1345402287
I've read many topics about idling problems from this and other forums, but nothing has helped so far. So I made a new topic. I'll try to type as best as I can in English :P
When the engine is cold revving is ok. As engine warms revs drop to almost normal, but k-light starts burning! Diagnostic codes were 52 and 53. First one is mixture regulation and the second is related to charging system(although generator seems ok). If I turn off the engine and start it again then at first revs are normal, but after a few seconds they start rising
SAD closes normally
Timing is OK
TPS might need some adjustment, any help for that?
A vacuum leak?
The car: 1992 1.9 SRi, motronic m1.3 with CAT
KRISKARRERA
Mixture regulation? Could that relate to the air flow meter being faulty perhaps?
estland1345402287
Ok, I'll try to test that later. I'm also suspecting a faulty o2 sensor, might this be a source of problems too?
estland1345402287
AFM seemed to be working if I checked the resistance while moving the flap. So the problem should be elsewhere.
OT: Is my account validated or does every post need admin's approval?
estland1345402287
I checked the MAF sensor pins resistance while moving the flap and it seemed ok(although it may not be) anyways any help is appreciated :(
edit: If it's vacuum leak how big it should be that ecu gives a k-light? Could a needle hole be enough?
Edited by estland
B1ack_Mi16
A blowing exhaust can also give K-light if it blows before the lambda sensor.
My Mi16 used to do this when the manifold was cracked...
Can be lots of different things, but you shouldn't have a big vacum leak I would guess before you also will get the K-light...
Jer309GTi
Hi there, your account should be validated, I have sent admin a PM to validate you
estland1345402287
My post no. 4 was made when my account wasn't fully validated, thankfully I got it done :)
Anyways exhaust manifold was ok, no cracks :D . Might be a seal then which I haven't checked carefully
Edited by estland
estland1345402287
Been a while since I last posted. Anyway engine is now working better than before. First cleaning the afm helped a bit. The source of these problems was a leak at inlet manifold. Also when putting back the manifold water started to leak! in 205 forum I found the thread about it, so might be useful. http://forum.205gtidrivers.com/index.php?s...c=112901&hl
Anyways topic closed :)
