calvinhorse
Rear Beam Rebuild Kit..
calvinhorse
does anyone have, or fancy writing up, a list of parts needed to rebuild a 405 mi16 rear beam?
Borntobewild
That could be interesting, gonna piggieback on this topic :)
Jer309GTi
I've got a parts CD that lists it all, but I'm midway through moving house so its hidden in a box somewhere! As soon as I can find it I'll post up the part no's :)
513148 ARM BEARING 8.04 GBP
513149 ARM BEARING 15.20 GBP
513260 SEALING RING 1.77 GBP
surprisingly little to them compared to a 205/306/306 beam.
calvinhorse
excellent, cheers welshpug!
2 of each i take it?
yup, about £50 in total, never taken one apart though I have lowered one, it was a doodle even though it had never been apart (Vicki's track car)
Jer309GTi
Thats good, I didn't realise there were so few parts :)
Mr Teflon
Don't forget the price for the thicker partner torsion bars ....... :)
B1ack_Mi16
Problem with 405 beams is the bearing surfaces on one side is usually gone.
So instead of having the possibility to only change the bearing shaft as on the 305/309/306 design on the 405 you have to change the complete beam tube (as the shafts are pressed into the tube instead of into the arm). And that's not cheap!
Hopefully yours is ok, but I've had 4 of these beams apart and 3 of them were completely gone on one side, and the last one was perfect on one side but was starting to go on the other. I've put it togeather as that though and will just have to see how long it will last.
calvinhorse
got it in bits, one side is slightly worn but nothing to worry about, the other side is perfect!
calvinhorse
yerp! above parts cost 45.02gbp with my 10% psooc discount
swing
