RaulM16
Estimated Mod's Gains
RaulM16
Hi everybody:
After reading a lot of info here and in other websites i have done a matrix with a lot of possibilities of mod's and the gains each one would aprox obtain.
STAGE I Mod's
KW Mod's
84 xu9j4
93 xu9j4 + Stage I
96 xu9j4 + Stage I + CR 10,8
99 xu9j4 + Stage I + ECU
101 xu9j4 + Stage I + ECU + LS1
104 xu9j4 + Stage I + ECU + LS1 + CR 10,8
107 xu9j4 + Stage I + ECU + LS1 + CR 10,8 + 45mm TB
STAGE II Mod's
KW Mod's
84 xu9j4
98 xu9j4 + Stage II
101 xu9j4 + Stage II + CR 10,8
104 xu9j4 + Stage II + ECU
105 xu9j4 + Stage II + ECU + LS1
107 xu9j4 + Stage II + ECU + LS1 + CR 10,8
112 xu9j4 + Stage II + ECU + LS1 + CR 10,8 + 45mm TB
113 xu9j4 + Stage II + ECU + 45mm TB + Big Valves
115 xu9j4 + Stage II + ECU + LS1 + CR 10,8 + 45mm TB + Big Valves
Some of them are results from PeterT, other are estimated results, and now the question, is this matrix correct?
Please anyone add additional gains with different mod's to obtain a matrix in which we can focus, for example if someone wants 100 KW there are several ways to achieve that amount of wheels KW, each way has different cost associated and of course the KW curve is different.
To ilustrate this better if we compare this two Mod's:
A) 101 KW xu9j4 + Stage I + ECU + LS1
B 101 KW xu9j4 + Stage II + CR 10,8
Both have the same peak power, the A) option is more expensive and i think A) option is more powerfull at medium rpms...
This is only an idea to obtain finally a matrix with good info to focus in what we want. The different ways to obtain it, the asociated cost and torque at medium range, not only the peak power as we usually look.
cammmy
So "115 xu9j4 + Stage II + ECU + LS1 + CR 10,8 + 45mm TB + Big Valves" would take an XU9J4 to approx 315hp? (if it adds 115kw) Is an XU9J4 not 120kw standard?
Guest scottcmb
i think he mentioned KW's at the wheels in his post
Guest scottcmb
Hi everybody:
STAGE I    Mod's
KW  Mod's
84    xu9j4
93    xu9j4 + Stage I
STAGE II    Mod's
KW  Mod's
84    xu9j4
98    xu9j4 + Stage II
Dont you think you need to think about what is driveable on the road???......unless you are doing a "track car" which is a different story
petert1345402284
I think that's a valid matrix for power at the wheels, although there will always be variations between dynos, engine builders etc. All of those options are still very drivable on the road, as there is still a very flat torque curve. That's just the nature of the beast. Increasing the CR, improving the ignition, getting rid of the AFM, all increases low end torque.
RaulM16
Sorry, the matrix was wheels KW instead of gains KW
I think a 100KW Mi16, with 7500 redline will be driveable.
I don´t pretend to do a "track car", I just pretend to do a list with wheel KW with each mod to know different ways to achieve HP gains, the cost, .....
So, if someone wants a road car, probably he will select the "cheapest" increase of power. Fot example a Stage II with CR 10,8.
And if someone wants a track car, the most important is to obtain maximum HP, and some times the price of the last 3 or 4 KW of gain are more expensive than the first 20 Kw of gains.
petert1345402284
I can vouch for that. Here's my son's Mi16 - Stage I cam, 10.8:1 and my chip. Not quite 100kW but getting close.
Edited by petert
RaulM16
Peter T, do yo have a similar Dyno but for the stock engine to compare torque and also other with Stage-II to compare torque too?
Thanks in advance.
petert1345402284
Here's a 16V before and after 45mm throttle bodies. Cam was Stage II, 10.4:1. Not my engine though and different dyno.
Edited by petert
RaulM16
Thanks,
And an additional question is: Which method did you use to raise the CR of your car to the 10,8:1?
which is the quantity of metal in mm i have to cut? 0,5 mm?
Thanks again,
Sejo
Just like my engine spec. B)
@Peter: chip hasn`t arrived yet :unsure:
petert1345402284
Thanks,
Thanks again,
Approx. 1.4mm from the deck/liners of a DFW, or 0.4mm from a D6C.
Sejo, I posted it last week, so expect it very soon.
RaulM16
Thanks Peter,
In relation with the inlet cams:
I have seen differetn Stage I models, but for example regrind one and new one are different in lift.
Your 96,3 KW with chip, 10,8 and Stage I are with a regrind or new one?
I suposse the new one has a little more torque/power as it has more lift.
petert1345402284
That's with a regrind.
RaulM16
Does the new stage I cam has any problem (interference) with the pistons rising the CR to 10,8 as it opens a little more the inlet valves?
petert1345402284
No, not with the Stage I, there's ample room. With the Stage II however, you need to verify how much clearance you have however, as it's on the acceptable limit.
