Jer309GTi
Powersteering Belt
Jer309GTi
Anyone know the size/length of the powersteering belt for the phase 1 Mi? Mines stretched loads so it won't adjust so need another. It's just a normal V belt isn't it? Looks like one. Cheers
petert1345402284
Just a normal vee belt, 10x550mm from memory.
Roland1345402284
Peter is correct 10x550
I replaced mine a while back.
I followed the Haynes book (section 1 page 11- blue book) to tension it correctly and after a few weeks of bedding in I retensioned it again.
There's a 1/2" square hole in the bracket which your 1/2" torque wrench will fit into.
The initial tension is 55NM (new belt) and the tension after the belt has bedded in is 30NM (not new belt).
I haven't touched it since and it hasn't been a problem.
My old belt was a toothed type but the new one is plain.
As I say tension is correctly and it shouldn't be a problem.
Jer309GTi
Thank you very much! :) Just out of interest is this belt the same size as the derv vacuum pump belt?
Roland1345402284
Dunno.
Mainly cos I dunno what a "derv vacuum pump" is!!!
petespug405mi16
i put a slightly smaller belt on mine as the one that was meant for the car was to big and i had no adjustment and the square bit you put a 1/2" torque wrench into was rounded off
Jer309GTi
Dunno.
lol :) the vacuum pump for the brake servo on a Peugeot diesel engine
Roland1345402284
Dunno.
Now I understand.
But I still dunno as I have no experience with aforementioned diesel engine!!!
KRISKARRERA
I think mine probably needs doing too. Can they be had from anywhere or is it a main stealer special?
Roland1345402284
You can get it from anywhere - it's a standard belt.
The one I took off is a Bosch, The replacement one is a Dayco.
Jer309GTi
Been round my usual motor factors today and no-one stocks a belt that small. I'll trawl tinternet a sec and try and get one. I'll post up if I have any joy
Jer309GTi
Hmm its proving difficult to get a belt the right size :( Everywhere I go the only answer I get is 'we don't do one that small, it can't be for a car being that small' :rolleyes: Anyone know a UK supplier of a 10x550 please?
KRISKARRERA
So is the defo no longer available from Pug?
I was looking at my dads GTI6 other day, similar pump on that engine, only its running directly off of the camshaft instead of via a belt. Why Pug didn't make the XU9J4 like that the fools lol
because they were using old skool dizzies :lol:
KRISKARRERA
No Mei, it runs off of the end of the exhaust camshaft so surely they coulda done that on the xu9j4 too.
Jer309GTi
God knows, they must've had a good reason back in the 80's :)
Ryan
My local halfords had them last time I checked.
Jer309GTi
Wish mine did :( the smallest they stock is 600
KRISKARRERA
I'll have a butchers next time I'm near Halfords.
Jer309GTi
Pug still stock them, I got one from them in the end. Around £12 :o
