Guest elmitchio
Driveshafts
Guest elmitchio
need to replace both bloody driveshafts on the mi, the 18's hav destroyed them! just wonderin if i hav to get mi16 ones, or are they all the same for p1 405's or wot? and does anyone know how much they are? or a cheap place to get them from perhaps lol
KRISKARRERA
Is the ABS still working?
I expect your 40mm drop hasn't helped the drive shafts much.
Guest elmitchio
nah took the abs out, was better without it lol!
Jer309GTi
I've looked in the GSF catalogue and it lists quite a few different part numbers for 405 driveshafts, so they are not all the same.
Toffer
The driveshafts for these cars looks like a jungle to me.
I know the GTX-ph2 and Mi-ph1 shafts can be swapped, however the amount of splines inside is different. I believe its the same situation with most of the 405's, like the SRi ph1, GLX-ph2..
Guest elmitchio
ok, well thanks for the help. looks like i'll just hav to buy sum new ones, chances of finding one at a scrappy are pretty slim lol
Toffer
Better new than used, you never know if they'r gonna last for weeks or years, even if they seem tight at first.
