Guest franco
Front Brake Calipers
Guest franco
Are the front calipers on series 1 Mi16 the same as calipers on other 405's (such as the SRi, etc)?
Reason I ask is that occasionally, the right hand front brake squeels, but not all the time :huh: Was wondering if this could be due to the brake cylinder could be on its way out. If so, instead of rebuilding it (which I guess could be costly), I could just purchase a caliper off another 405 (Mi16 or not) in good condition to replace it.
Also, what is a good compromise for a road/track brake pad? What do you guys run? I have used Lucas pads in the past (on a couple of daihatsu charade turbos) with good results (especially for what they cost), but any other suggestions welcome. Was thinking about Bosch pads, but have no experience with them, such as these I found on ebay:
http://cgi.ebay.com.au/DISC-BRAKE-PADS-PEU...1QQcmdZViewItem
Guest DesMi16
There were 2 calliper types fitted to the 405's. The Bendix were on the lower powered models and the Girling were on the higher powered models. AFAIK, the SRI callipers will fit the Mi.
My favourite fast road / track pads are the Mintex 1144's. Good all round stopping power even from cold .
Guest franco
if there is any difference, mine is a non-ABS model
Guest franco
also :unsure:
are the front discs used the same between all series 1 peugeot 405's?
Guest Eric Josefsson
My favorite pads for "normal" road/track was Tarox, atleast for one season, when it had been standing still over the winter and i went out on the tracks there was no "bite". Don´t know why, but they just had lost it.
Don´t use Greenstuff.. they lasted 1½ trackdays for me.
If you can stand "some" :rolleyes: squeaks Performace friktion PFC97´s works good on road (even cold) and is a really good racing pad, they never fade, they stand ALOT of heat(if you can drive them to it) and they last really good. Unforunally they don't exists in a shape that fits the caliper, but there is another pad thats very easy to modify to make it fit..
Another downside is that they eat alot of disc when cold..
cost around 140£ (calculated from swedish prices with 25% VAT)
Rippthrough
Mintex 1144's, or Ferodo DS2500. Got the ferodo's on one car and the mintex on another, and they are both superb pads.
AlexN
Can anyone give me a link/number to someone selling Mintex 1144 for an Mi16? Thanks.
Rippthrough
Give Rally design a shout, even if they don't stock them they can usually source them for all sorts of cars.
www.rallydesign.com
AlexN
Thanks, i'll give them a try.
KRISKARRERA
also :unsure:
No the models that had the Bendix calipers had solid from discs and drums at the back.
vicki mi16 babe
I use ferrado ds2500 on mine.They have great wear and last well on track use,
