TBC WEBER 45s
309 Runing Gear Back Beam And Up Front
TBC WEBER 45s
Ok all.What I was thinking is I have a 309 4 door f reg 1.9 gti 47000 mil and have the runing gear of it and put on my 205.Have had a look for info but no joy lots of end of jobs but no start to finish.If anyone can give me the time will be a great help thanks
calvinhorse
Unbolt 205 suspension and drive shafts bolt on 309 suspension and driveshafts
Job done its that simple ;)
Edited by calvinhorse
TBC WEBER 45s
thank you but I was thinking will that give me a hell of allot of - camber and will I have to go with coilovers and adjustable top mount.Is the back beam a plug and play the bump stops will not be in the same place?
allanallen
No it'll give you just over 1 degree of negative camber on the front, if you've done a search you'd know that already though?!
TBC WEBER 45s
thank you got to say did not look to much in to the front end more the back but I had to ask at the same time sorry for being lazy
TBC WEBER 45s
Well that's the front thank you anyone for the back beam
Rear beam bolts directly on, just the rear sandwich blocks need turning 180' to match the boot floor holes on the 205 & 309 beam combination.
Its a well documented swap on here.
The rear arch trims will also need trimming inside the arch because the rear tyres catch, especially if you've lowered your car at the back.
g
TBC WEBER 45s
Nice one.Nice all the info in one place.
johnnyboy666
and several other places :P
TBC WEBER 45s
Ok I am back do you think it is worth doing the anti-roll bar at the same time?and is it a plug and play
Front or rear?
Some 309 GTI's had the same size front arb & some a 21mm.
Front arb will fit straight on but its questionable how well suited the 205 is to swapping front one from 17mm to 309 21mm item, most don't like it iirc but can't speak from experieince.
Leave rear beam as it is, unless you have an uprated arb to fit but a 205 arb is to narrow.
g
jord294
You'll also have to rotate the 2 x two studded brackets on the 309 beam, to fit it to the 205.
TBC WEBER 45s
Front or rear?
g
yer up front is a 21mm arb. I was thinking it will work beter with the 309 back beam than the 17mm 205 front arb.Thanks
I'd leave the thinner 205 arb up front, let the wheels move over bumps more rather than move the car about, its lighter than a 309 dont forget, allbeit minimally
